1200 l series crossmember
From Gold Coast
It's a long shot but is anyone selling a datsun 1200 l series crossmember for l 20b?
Posted on: 2015/9/18 11:16
Re: 1200 l series crossmember
From Armidale N.S.W
Ill take a trade for one it needs finishing its designed around an L18 with stanza sump, can upload pics tomorrow. I would offer to finish it off and paint it but i sold the L18 2 days ago.
Posted on: 2015/9/18 13:07
73 1200 wagon SOLD
If you wish to use a mid-sump L20B engine, then the stock PB110 crossmember is the go.
With a front-sump L20B you can use a regular B110 crossmember without modification. Fabricate new brackets for the engine. See L/Z/KA/SR Crossmember.
Posted on: 2015/9/18 22:54
From Gold Coast
I have been told the l series 120y one fits with not much modification and have bought one to try, just waiting for it to arrive, what stage is yours at datsandy again, I don't have a crossmember to trade mine has none :(
Posted on: 2015/9/22 2:13
Are you ordering out of Japan (L-series B210 crossmember)? The tech section says it is wider than a 1200 crossmember which may or may not be true. But more importantly it uses 510/610 (180B) style LCAs. Let us know how it works out and post some piccies? Thanks.
Posted on: 2015/9/22 6:52
From Gold Coast
Picked one up in NSW, not sure I'm hoping it's true
Posted on: 2015/9/22 11:27
From Gold Coast
jpg  image.jpg (108.02 KB)
6639_56012e0c1faa2.jpg 640X480 px
Posted on: 2015/9/22 11:32
Looks like it. Uses the mid-sump oil pan from the 510/610.
The factory B210 L-series crossmember is identical to the 510 (1600) crossmember except reportedly the holes drilled for the control arms are slightly inboard (just slightly).
If that is for B210/1600/180B, the holes should be 761 mm across and 52mm(?) apart.
Posted on: 2015/9/22 11:57
From Gold Coast
Not sure it hasn't come yet, what's a 1200 measure across? U think it will work
Posted on: 2015/9/23 1:57
From Gold Coast Queensland, Australia
There's one on bay for $100 if the one you ordered doesn't do the trick. The seller quoted $36.25 postage to GC
http://www.ebay.com.au/itm/Datsun-120 ... 82023?hash=item3d03b7cc07
You will still need to modify the towers tho.
Posted on: 2015/9/23 3:52
1200 ute
L20b
