Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Car Starts and die suddenly
Posted on: 2015/12/22 4:59
Many things can cause those symptoms
including: * Idle set too low * Air leak A few years ago the idle stop on my 1200 came loose, and the idle dropped too far
#12
Datsmithy
Posted on: 2015/12/22 7:08
Hi SumIth,
I'm not sure if your carby has an anti deiseling valve but if is does this can cause problems and cause the engine to cut out. Check there is power at the valve when the ignition is turned on. But as dd said there could be few things to cause this problem.
#13
Sumith
Posted on: 2015/12/29 5:48
Hi Guys
I don't have Anti Dieseling Value on my carb, Just Removed the carb and cleaned it completely and fixed it Problem got solved could be a blocked situation. thanks for the ideas regards sumith
#14
Posted on: 2015/12/29 10:55
Glad to hear you got it solved. The basics solve all kinds of problems -- good on ya
