#1 Few Problems to be clarrified in Speedo and Signal
Sumith Posted on: 2016/1/14 10:13
Hi Guys
I have few problem in my b210
My Speedo meter is stuck on 80 doesn't go down or up
when i press trip reset button it comes down to zero and then again it goes upto 80 and get stuck (even though i don't drive to 80 it goes up)
sometimes Left Side signal doesn't flash,only Dash indicator shows but doesn't flash at all just stay on,
Rear and front lights are not working at all
Right hand side is ok working fine
what would you guys idea about them ?
thanks
regards
sumith
#2 Re: Few Problems to be clarrified in Speedo and Signal
ddgonzal Posted on: 2016/1/14 21:47
The speedometer unit has a physical problem. It will need to be removed and inspected (or replace). Once it is out, check the freeness of the needle.
The flasher is load-dependent. If it doesn't have the right load, it will not flash. The load is put on it by the number of bulbs in operation. So most likely there are bulbs on that side which are not working, perhaps burned out.
#3 Re: Few Problems to be clarrified in Speedo and Signal
devilzyas Posted on: 2016/1/15 0:05
re the flasher: could be a grounding issue as well.
last year while doing some maintenance, I forgot to bolt back the ground wire on the fuel tank behind the rear seats.
the flasher would work fine without headlights on, but with the headlights on, the dash bulbs would stay on as well as the flasher indicator, both sides
i found the issue only after spending hours removing all the wire harnesses and testing the circuits
it could be something else in your case as its only one side affected, but would be worth checking....
Regards
Yasseer
#4 Re: Few Problems to be clarrified in Speedo and Signal
Sumith Posted on: 2016/1/16 7:09
Hi Guys
Thanks for ideas i will check it back, Few Months earlier it was reading inaccurate for about 2 months, Then after it worked perfectly accurate for another 2 months, then after i wanted to reset my trip meter it was not reset to zero also, after that this incident happened
thanks
regards
sumith
