« 1 (2)
Re: best place to get oversize a14 pistons?
Quite a regular
precission international ph1300346350
Posted on: 2016/3/17 4:02
From Sydney Australia
Precision supply Bursons and probably everybody else and do most of what you would need and also supply ARP rod bolts, K&N Filters and Transmission kits and a whole host of parts for A10, A12, A12a A13 , A14 etc so worth bookmarking and the online search is 4 pages just for A14 and nicely they give you dimensions such as Valve Head Diameter, Stem Length and Diameter all of which allows you to figure out what else may fit if for instance a 0.5 MM oversize valve head means you don't have to replace valve seats due to recession or too many refaces over the years because a slightly bigger head valve moves the seat to an unworn part of the valve seat insert.
So much usefull information can be found on their site for any number of suppliers brands.
http://www.precisionintl.com/Default.aspx
Posted on: 2016/3/23 12:02
Re: oversize a14 pistons - RB20E
From Hawaii, USA
RB20E 78mm bore, same pin size, same pin height
domed with valve cutouts
* Nissan 12010-55S01
$92/set of four from Alibaba
Not really the right shape for wedge heads like the A14 but potentially an inexpensive source for high-compression pistons -- maybe massage the dome a bit
jpg  Nissan RB20E piston.jpg (31.35 KB)
174_5c85a949509b0.jpg 640X480 px
Posted on: 3/11 0:19
« 1 (2)
