Electronic Speed Sender in standard 4 speed box
From Nambour, Sunshine coast, QLD
please could someone tell me if this is true, its what i have found searching the WIKI:
R31 has a electronic speed sender, and it will fit a standard 4 speed box (i have a 1200 ute).
if not can someone tell me how to put an electronic speedo in my ute with the standard box.
Cheers
Posted on: 2016/5/2 4:41
Re: Electronic Speed Sender in standard 4 speed box
R31 with CA18 engine uses 71C standard gearbox. The 71C speedometer sender will fit into a 60-series standard 4-speed (e.g. B310 A14/A15 gearbox)
Posted on: 2016/5/2 5:21
There are two part to putting an electronic speedo in:
1. Fitting the speedometer into the 1200
2. Fitting the speedo sender into the gearbox
Auto Meter sells various sizes and styles of electronic speedometers
Or, some guys fit an entire S13 cluster into the dash. Not sure if you can fit the Nissan speedometer alone
S13 dash into 1200
S13 cluster into 1200 dash
For the sender, choices include:
* Swap the 56-series 4-speed for a 60-series 4-speed, then unbolt the mechanical speedometer drive and bolt in S13/R31 sender
* Modify the 56-series cable drive to accept the Nissan sender (cut & shut? or machining?) I haven't heard of anyone doing it
S13 electronic sender
Posted on: 2016/5/2 6:20
Thanks ddgonzal, I appreciate it.
I think i will get hold of a s13 sender and see what i can do. Ill add info somewhere later if I have a win.
Posted on: 2016/5/2 8:45
*1984 1200 Ute
