OK very tough to really diagnose without either a laptop or a hand controller to see what the ECU is saying.
For power there are two wires you need to check:
- Red wire from Lt10s should be going direct to the battery (should have inline fuse).
So this should always have +12v to it regardless of ignition position.
- Pink wire from Lt10s should be going to an ignition switched 12v. So power stays on when ignition is switched on. I think I wired mine to the wire that went to the cigarette lighter.
This pink wire is split and is also used to power the fuel pump.
So you should be able to check power to both these wires with a simple test light.
There is also a calibration process for the TPS (throttle position sensor)...but you would need the laptop program or hand controller to see the readings. Correction...apparently you can use the amber light on the ECU to tell when it is set to 0.
Found this on a quick Google search and it explains the TPS calibration steps.
http://www.sonicinjection.com.au/uplo ... 20Quick%20Ref%20Guide.pdfWhere abouts do you live...if in Melbourne I could loan you a hand controller.
