« 1 ... 9 10 11 (12)
Re: diff ratio and wheel size.
Replaced my 4.11 to 3.89 diff. Now I can stay longer in each gears..,
Posted on: 2017/6/14 3:18
Hi all.
Too much negative offset front wheel will effect the handling?
Posted on: 2017/7/26 6:10
Edited by smariese on 2017/7/26 6:38:55
I think no. The most negative offset that will fit is not very much. Skinny tires will affect the handling more than the offset change
Posted on: 2017/7/27 7:04
my front strut is from bluebird 910. which is already widen the front track + 13x7" deepdish wheel + w50 ball joint. rear wheels track is much shorter.
in parking, if i press the brake and turn the steering wheel, its almost impossible to turn.
I feel oversteer effect in cornering, even i don't step on gas pedal.
front: bluebird standard oil absorber + progressive/dual rate coil spring from B310 EGI
rear: sunny B11(130y) standard gas absorber + progressive/dual rate coil spring from B310 EGI
anything wrong with these set up? or do i need a good wheel alignment ?
Posted on: 2017/7/28 7:50
For front, I welded the spring seat 1inch lower. For rear is standard height. Different height will make the car tail happy.?
Posted on: 2017/7/28 11:29
In my experience lowering the front of a car 1" has not caused oversteer or any noticeable handling problem
YES, make sure the toe-in is within specification. You can set that yourself. If it solves the problem no need for a full alignment
Posted on: 2017/7/29 5:07
alright. thanks.
btw my tire size is 175/70/13.
Posted on: 2017/7/31 6:57
i removed rear sway bar to paint it white. while driving without rear swaybar, i can notice significant reduce in over steer. feel like the car no more tail happy.
# 23mm holly rear sway bar. came with b310 egi.
Posted on: 2017/9/12 16:51
