will i need to notch my bores?
ok i have a A15 with the standard offset dished pistons. GX .6mm head gasket, valves are 37/33 and running a wade 140 cam. with this setup do you think i will need to notch the bores? does anyone have the same or similar setup?
i ask because my bottom end is all done and assembled but the head work isn't done yet so i couldn't check before the bottom end was rebuilt.
fingers crossed i wont have too. also what is enough clearance for valve to bore?
Posted on: 2016/8/11 0:18
Re: will i need to notch my bores?
37 is the factory size, while 33 exhaust is larger than factory size of 30 (late A15 intake was only 35mm intake, while 80HP A15 came with 37mm intake valves)
As little as .005 inch is enough clearance, but more power will be made with .075 inch clearance as it lets air flow around the valve head
Posted on: 2016/8/11 1:52
From Sydney
Its primarily the exhaust valve that needs the clearance in the cylinder wall, as the inlet is located move centrally in the bore. The exhaust sits off to the side.. Especially when you increase the valve head diameter and/or increase the exhaust valve lift. Dummy assembly of the long motor is the go.
Posted on: 2016/8/11 2:01
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
i guess i'll have to wait and see. i'll keep my fingers crossed.
is the best way to check by looking up the bore from the bottom?
thanks again guys
Posted on: 2016/8/11 2:30
Use a bit of modeling clay or play-doh, turn the crank two full turns to ensure full a cam cycle and see how far the clay has been squished
Posted on: 2016/8/11 3:53
isnt that what you do for valve to piston clearance? or is it the same process for valve to bore clearance?
Posted on: 2016/8/11 4:21
Good question, yes, same process, except for checking valve-to-bore do it with pistons removed
You can do variation with it, for example, instead of rotating engine, push the valve down manually (with light testing valve spring). That way you can check even larger valve lifts (larger than the cam you have). Or you can skip the clay and use flexible feeler gauges to measure the clearance
Posted on: 2016/8/11 4:45
do you think its necessary to check piston to valve clearance even with dished pistons?
Posted on: 2016/8/11 5:08
From Las Vegas USA
Go to this link, it gives you the block spec for various cams & valves. It's very handy
http://www.datsuncherry.ch/PDF/Rennteile75.pdf
with dished pistons I wouldn't expect clearance issues but you should check it to be sure.
Tom
Posted on: 2016/8/11 5:21
From Perth
38 inlet
33 exhaust
77mm bore
Not sure if I notched or not... but think I may have
Posted on: 2016/8/11 12:01
