« 1 (2) 3 4 »
Re: 13B Rotary Swap
From St. Louis, MO
Really interest on this set up!!!!
Yes Rotary parts are no cheap!!! I'm already set with my engine.. around 650whp with a 74mm Precision Turbo
Posted on: 2016/10/13 8:03
Re: 13B Rotary Swap
From Hawaii, USA
The setup uses
* Wilwood Dynapro Single, 3.25" Lug Mount calipers
* Drilled Steel rotor (thin), 6-hole mount
I cannot find the hat he is using, but if you call Wilwood, they could advise
Datsun 1200 strut
* 3.25" caliper lugs
* 4-on-87mm rotor bolts
* 70mm registration hole
* rotor bolts behind hub
Posted on: 2016/10/13 9:48
Re: 13B Rotary Swap
From St. Louis, MO
Added pictures to the iinitial post
Posted on: 2016/10/23 20:42
Puerto Rico! Home of the fastes Rotary engine cars! Period
Re: 13B Rotary Swap
From Hawaii, USA
Wow, it's looking good. 13BT!
Posted on: 2016/10/23 22:43
Re: 13B Rotary Swap
From St. Louis, MO
Thanks,
Posted on: 2016/10/26 13:04
Re: 13B Rotary Swap
From St. Louis, MO
Finally installed my Wilwood front brake set up and spindle
http://i90.photobucket.com/albums/k26 ... 75DB09304_zpsn7oyxac7.jpg
Posted on: 2016/12/16 23:48
Re: 13B Rotary Swap
From Hawaii, USA
Hey those look nice. Which Wilwood part numbers are they? It looks like custom Hub too
jpg  8EA2DFDC-E43A-4F19-9DE2-CC775DB09304_zpsn7oyxac7.JPG (126.24 KB)
174_5854a076106e7.jpg 450X800 px
Posted on: 2016/12/17 2:18
Re: 13B Rotary Swap
From RSA
hey DD the brakes are nice.Is it a standard 1200 strut and is there any mods.Is there perhaps a number for the brakes.The studs are [5] but are they available in 4 stud too.
Posted on: 2016/12/18 7:52
Re: 13B Rotary Swap
From St. Louis, MO
Sorry guys, haven't log in here a while...
Posted on: 2017/1/9 2:25
Re: 13B Rotary Swap
From St. Louis, MO
Here is the latest update on my Rotary conversion... almost done with them. I nitially start with the idea of doing a ladder bar setup that would allow me keeping the rear seat with hour cut from g the floor. Aside the tubbing.
http://i90.photobucket.com/albums/k26 ... 88DE10434_zpsyjvkrtnk.jpg
http://i90.photobucket.com/albums/k26 ... D893642EA_zpsbpuyeb4t.jpg
http://i90.photobucket.com/albums/k26 ... BBD15B61A_zpsqjhsltkr.jpg
http://i90.photobucket.com/albums/k26 ... 3F7E3EF96_zpsilj78qzo.jpg
Posted on: 2017/1/9 2:38
« 1 (2) 3 4 »
