« 1 2 (3) 4 5 6 »
Re: a14egi vs 15egi
From Melbored
stock carb is much simpler to maintain and looks the goods
unless you are after economy, turbo forget it.
Posted on: 2016/10/17 4:07
https://www.youtube.com/watch?v=FEheU28ea3c
Give me control of a nations money supply and I care not who makes the laws - Mayer Amschel Rothschild
Politics not the oldest profession yet same result http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf
Re: a14egi vs 15egi
From Hawaii, USA
I beg to differ. EFI takes less to maintain. No regular adjustments are required. Runs smoother, more economy more power
Posted on: 2016/10/17 5:11
Re: a14egi vs 15egi
i drove my previous a15egi for about a week before sold the egi system to a forumer. It runs definitely smoother. but i feel my current twin SU is more powerful. maybe because the car was left for years and faulty wiring(?)
Posted on: 2016/10/17 6:57
Re: a14egi vs 15egi
should i file this are in red circle?
jpg  gasket.jpg (118.54 KB)
17554_58047c11298e9.jpg 415X234 px
Posted on: 2016/10/17 8:21
Re: a14egi vs 15egi
From Melbored
It could reduce atomisation and cause flat spots
Posted on: 2016/10/17 8:31
Re: a14egi vs 15egi
Hi, you mean I should file the head there to avoid flat spots?
Posted on: 2016/10/18 2:28
Re: a14egi vs 15egi
From Hawaii, USA
grind this part, using the gasket as a guide. Do not make the ports larger (they are fine-tuned for max HP in the 3000-6400 RPM range)
jpg  EGI porting.jpg (72.54 KB)
174_580582053decd.jpg 198X234 px
Posted on: 2016/10/18 2:59
Re: a14egi vs 15egi
thanks.
a14/a15 came with carburetor and efi. ga16 also carburetor and efi. So, can i adopt GA16DE wiring and ecu to make my a14e/a15e work?
Posted on: 2016/10/18 4:50
Re: a14egi vs 15egi
From Hawaii, USA
GA16DE is volumetrically higher efficiency so the ECU may not be a good fit (16-valve engine vs 8-valve engine)
But may work fine (earlier Datsun ECUs were self-tuning when used with the matching Airflow Meter). Adapt a Nissan Optical CAS unit to the A-series engine as that's what the GA16DE ECU uses for an input. Use the ECU with its matching MAF Sensor, and a portion of the intake tubing, try to make it similar to the stock configuration. The MAF can be supposedly be set using the KEY ON-KEY OFF procedure.
Will this work on the A-series engine? Probably, but how well I do not know
MAF for USA-spec 1992 GA16DE with NVCS
Nissan 22680-55Y00, 22680-57Y00/22680-57Y02
* The MAF bolts to the air tube and is calibrated for flow through this aluminum casting
* In the last photo you can see the sensor (silver air contacts) in the small dark hole
jpg  Hitachi MAF0093.jpg (172.39 KB)
174_5805df4380c66.jpg 974X1200 px
jpg  Walker 245-1073.jpg (161.39 KB)
174_5805df8898e04.jpg 1500X1500 px
jpg  Standard MF20052.jpg (41.12 KB)
174_5805dfa690eb3.jpg 416X450 px
jpg  Standard MF20052_.jpg (58.92 KB)
174_5805dfb3423a5.jpg 397X450 px
Posted on: 2016/10/18 10:09
Re: a14egi vs 15egi
From Hawaii, USA
Here's a Nissan MAF I fixed a few months ago from a 2000 QG18DE. As you can see the air contact is rusty-looking. It would start, but not run above idle. Spray cleaner fixed it right up and the car is running perfect to this day
jpg  20160428_165622.jpg (166.65 KB)
174_5805e777898e6.jpg 1600X901 px
Posted on: 2016/10/18 10:12
« 1 2 (3) 4 5 6 »
