Confirm transmission body boss size & thread pitch.
From Las Vegas USA
Wanted to confirm the bolt size and thread pitch for trans boss (spot welded piece inside tunnel), I believe they are M10 1.5 pitch.
In the course of fabricating and fitting an adapter plate for 60 series transmission (stock mount on tail shaft) I need to use longer bolts. For the purpose of test fitting I actually used some head bolts. Note the motor and transmission on my car are moved back 45mm. Basically I have a U shaped plate like the one in the photo gallery, I have spacers between the plate and tunnel mounts.
Tom
Posted on: 2016/10/25 6:03
Re: Confirm transmission body boss size & thread pitch.
Transmission crossmember brackets
14 08154-02510 BOLT-HEX MEMBER TO BODY FIX (2)
15 08915-14010 WASHER-SPRING LOCK TO BODY FIX (2)
16 08915-44010 WASHER-PLAIN M10 TO BODY FIX (2)
These are all M10 size (per NES)
08154-02510
08-15 bolt -40 M10 -25 mm length -10 standard finish
As thought head bolts were bigger than M10? Maybe yours are not original?
jpg  101-01a.jpg (41.60 KB)
174_580eed9cda29f.jpg 600X600 px
Posted on: 2016/10/25 6:20
Not sure what the pitch is, the parts catalog doesn't say
60A adapters like this use approximately 20mm spacers
60L adapters need no spacer?
Can you post the dimensions of the bracket here?
Posted on: 2016/10/25 6:30
