thermo fan controller
From Mordialloc
unfamilar was asking about these on Sunday so I thought I'd post it
have used these twice and they seem to work great
Very easy to set
https://www.ebay.com.au/itm/20A-12V-Re ... id=p2047675.c100005.m1851
Posted on: 2018/2/13 5:44
'79 B120 (TURBO EFI A15 + 60 ser.5spd )
'83 Clubman 7 with worked A15 + 63A 5spd
'73 1200 Coupe Mild A15 5spd lsd
keep it simple
Re: thermo fan controller
From Look who's back in town
Thanks Ziggy. Found heaps of 2amp computer ones was going to message you.
Posted on: 2018/2/13 7:23
Was B110 Sedan: L series
From Sydney NSW
Where do you stick the temperature probe? (no funny answers!)
Posted on: 2018/2/15 22:45
Awww dang it
Posted on: 2018/2/16 0:33
From Hawaii, USA
The sensor goes in the lower radiator hose
Posted on: 2018/2/18 21:54
From Sydney NSW
So could cut the sensor off the ebay controller and use one of those thermo switches. Rating for the temperature switch might be about 80degC? since it's on the outside of the hose it might not match the water temp exactly.
Posted on: 2018/2/18 23:58
From Hawaii, USA
Well the eBay controller is adjustable, is it not? I would use the sensor that comes with it. Never seen that kind before so don't know exactly how it mounts up but it's got to measure the radiator temp somehow
Posted on: 2018/2/19 2:14
From Sydney NSW
Ah right I get it. That picture is of a little $2 thermal switch, they have a cut in and cut out, usually something like 80C on - 70C off, depending on model. It's something you might use instead of the controller.
The ebay controller has a probe that could also be cable tied to the lower radiator hose or jammed in the radiator somewhere near there. Might read a little inaccurate though.
Posted on: 2018/2/19 4:10
I think he used 2 part epoxy into the heater fitting at back of head
Posted on: 2018/2/19 6:30
Not that it matters with the controller cause you can set the temperature
Posted on: 2018/2/19 7:07
