Browsing this Thread:
1 Anonymous Users
Wanted SR20DET (non vvt) |
From Newcastle
Hi guys I'm looking to buy an early model SR20DET (S13) to squeeze into my Datsun 120Y coupe (track car). I'm located in Newcastle but will travel to pickup. Cheers
Posted on: 2018/5/29 6:55
If you can't fix it with a hammer, it must be electrical.....
Re: Wanted SR20DET (non vvt) |
Registered Users Contentmaster Usermaster
You probably already know this, but for new readers ... there are two types of Variable Valve Timing on SRs * SR20VET - VVL. rear-mounted solenoids, takes some work to fit in a 1200 or 120Y * SR20DET S14 - VCT. side-mounted solenoid, fits well, needs no ECU (can wire a dash switch to select low/high RPM cam timing)
S13 is easiest to swap, the N-VCT on S14 is only 15hp more so no biggie. S13 inlet manifold is underslung so it won't interfere with RHD master cylinder
Posted on: 2018/5/29 7:31
From Newcastle
Yes already running an SR20VE turned north/south but think I need to step up to a turbo SR20 S13, cheers
Posted on: 2018/5/29 7:42
