Car Dies sometime
From Sri Lanka
Hi Guys
i have a problem with my b210 it dies after sometime and can't start again have to key it
5 to 10 minutes to start back,while driving suddenly i can't accelerate it and dies immediately when checking the carb float ball that time it is empty it does not overflow no any fuel smell,after srart it back it can go further 5 to 10 kms again that happens ,what would be the case ?
thanks
regards
sumith
Posted on: 2018/8/14 1:27
Re: Car Dies sometime
Sounds like a fuel problem, perhaps the fuel pump, or perhaps a leak in the fuel line (leaking air in, not necessarily leaking fuel out). When this happens no fuel will get to the carburetor so as you drive the carburetor will empty until the engine dies
What i would do next is
* Carefully inspect all the rubber fuel lines to ensure they are not cracked anywhere (it is most common to crack near the ends). Replace any damaged lines
* Inspect the fuel tank cap. If it is plugged it will cause engine to slowly run out of fuel
* Perform a Fuel pump pressure test (both tests)
Fuel Cap Test for all B210 Japan-market models:
* You should not be able to blow air out through the cap
* You should be able to suck air in through the nubbin
1. Wipe valve housing clean and place it in your mouth.
2. Inhale air. A slight resistance indicates that the valve is in good mechanical condition. Note that, by further inhaling air, the resistance should disappear as the valve clicks.
3. If valve is clogged, or if no resistance is felt, replace cap as an assembled unit.
Posted on: 2018/8/14 5:04
From Sri Lanka
Hi Guys
I think i found out the Issue,It was a piece of packing which got block between carburetor inlet valve which does not bring fuel inside the carburetor sometimes,when i
vacuum it i saw a peace sucked into the cleaner from inside the inlet valve
thanks
regards
sumith
Posted on: 2018/8/20 11:40
