A12 engine
From Brisbane
For free is an A12 engine. I left it out in the weather and the cover came off so water has got in to the combustion chamber via spark plug holes. The head should be fine. I'm disgusted with my self because it was a newly reconditioned engine 10 years ago!!!
Anyway it's in Hackett, ACT. It would be great to see it up and running again, when i had it, it would rev smoothly up to 5000rpm and more but i didn't take it beyond that. I miss the old A12s.
Justin - 0400285727
Posted on: 3/20 0:23
Re: A12 engine
From Melbored
Like all A12 engines ready for turbo from factory :)
Posted on: 3/20 0:51
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
Re: A12 engine
From Hawaii, USA
Yes ready for turbo up to 127hp with stock head & head gasket, and stock bottom end (stock rods, pistons, etc) -- see sikyne's turbo A12
But with water in the cylinders for some years, maybe this one isn't ready for it. But it may clean up and at least some parts will be useful
Posted on: 3/20 1:07
Re: A12 engine
From Melbored
bore and hone for a14 turbo pistons, e85 can handle surely 150hp
If tune is good double hp possible & will have better tq than sr20
Posted on: 3/20 6:40
Re: A12 engine
From Hawaii, USA
No need for turbo pistons. The stock A12 pistons can handle 160hp. Sikyne did that with stock H89 cylinder head and stock A12 bottom end
The key in making it last is control. See Safely Turboing the A12
Posted on: 3/20 7:24
Re: A12 engine
From Fort Worth, Texas
Hey DD...is there much difference between early and late A12 engine other than the oil pan and where dizzy lines up? Bores look to be the same with the exception of A12A engine. Advantages of one over the other? Any limitations with cylinder heads? I have early A12, with stock pistons, sitting on garage floor collecting dust.
Posted on: 3/20 19:24
Re: A12 engine
From Melbored
dont know how "turbo" got in front of pistons!
but meant using 75mm pistons would make sure
that rusty bores are fixed after 2mm bore and honing
Posted on: 3/21 3:39
Re: A12 engine
From gold coast QLD.
Sitting doing nothing turned on this site in godknows how long and see reference to Simons A12 turbo.
I can confirm the humble stock A12 can handle some fair numbers.
Mine came back from dyno 2 weeks ago with a re tune and more boost turning 161rwh on e85 jungle juice,been running 115rwh for the last 2 years on e85 without issues,well now see what happens on track
Posted on: 3/22 0:11
Re: A12 engine
From Melbored
Yes sugar spirits can make any A12 a beast with boost
Bert whats with your setup?
Posted on: 3/22 7:59
