Hotspark collar won't get past section of dizzie shaft
Not too shy to talk
From Berkshire, England
Hi there, I have a B211 with a Hitachi D4A5 (22100-H8301) and I am trying to install a hotspark ignition conversion but can't get the hotspark magnetic collar past an 18.2mm collar on the dizzie shaft. I attach a pic of the offending item. I'm also baffled by the 3 posts on my ballast resistor and the fact that the gap for the wires in the dizzie is way bigger than the replacement rubber insert that hotspark supply but I can silicon my way out of that one.
jpg  Dizzie collar.jpg (83.23 KB)
20817_5cb5d32676bd2.jpg 640X481 px
Posted on: 4/16 14:09
Re: Hotspark collar won't get past section of dizzie shaft
From Hawaii, USA
Is that hotspark designed for the distributor? It may be intended to be used on earlier distributor Hitach D40/D41 which was nearly but not quite the same
JDM B211 came with points distributor and 2-tap ballast resistor
3-tap ballast resistor was used by early electronic ignition (e.g Hitach D4F and D6F/280Z)
The middle tap is for the medium current load of the electronic ignition (0.9 ohms, which is too much current for a points distributor). When using Hot-Spark Ignition be sure to use the outer pair of connectors on the resistor as Hot-Spark is not a high energy module. They sell a Hot Spark "high-energy" coil but is just a normal coil (3.4 ohm). But you can use a regular ballast (1.5 ohm) with a regular Datsun coil (1.5 ohm, total 3.0 ohm)
Posted on: 4/17 7:26
From Hawaii, USA
Found this on the Hot-Spark USA site (didn't see it on the EU site): "kit's magnet sleeve fits distributor shaft lobes that measure 16.10 mm from flat edge-to-flat edge. A few Hitachi distributor shafts have a round extrusion or "bump," above the distributor shaft lobes, that prevents the magnet sleeve from being seated. In that case, you'll need to request a custom magnet sleeve that has the center hole enlarged"
jpg  Hitachi 4-cyl distributor with bump on shaft.jpg (84.06 KB)
174_5cb6cbd4c501c.jpg 800X450 px
Posted on: 4/17 7:46
From Hawaii, USA
Note the photo above looks like a D4A -- the grommit replacement rubber insert doesn't quite fit
This photo looks like a Hitachi D40/D41 (the type used by early B210) and it fits perfectly
jpg  3HIT4U1-in-Distributor.jpg (86.86 KB)
174_5cb6ceb21b674.jpg 827X700 px
Posted on: 4/17 7:57
Not too shy to talk
Many many thanks ddgonzal - as ever. I have requested the adapted magnet from E-spark europe who supplied it.
Posted on: 4/18 12:47
