Pulsar N12 Dissy
Iím looking at buying at N12 ET Pulsar dissy , has 4 wires coming out of it , no vacuum advance unit .Numbers marked on it are T4T844736125, then the Nissan number is 22100171416 . Will this work
Posted on: 6/29 1:07
Re: Pulsar N12 Dissy
From Hawaii, USA
T4T is a Mitsubishi housing
22100-171416 has one too many numbers. Perhaps it is 22100-27M16?
22100-27M16 DISTRIBUTOR ASSY N12.E16I MITSUBISHI
These are very reliable distributors with reliable optical sensor -- so it most likely still works unless it is visibly damaged. It will work with the Pulsar ET but I'm not sure how many others it will work with as most E16/E15 use a traditional EI distributor with vacuum advance
It is likely the second source (mitsu sourced) of the Hitachi D4P Distributor. Take a look at the photos listed there
Posted on: 6/29 5:43
