« 1 2 (3)
Re: 79 B310/210 auto to 4 speed swap questions
From Hawaii, USA
Good on ya. Should be more power and more driving fun
Posted on: 2019/8/3 12:13
From South Dakota USA/Trinidad and Tobago
Just fired it up. Seems to be running fine. I just unbolted the inhibitor switch from the auto n hooked it back up to the harness in park position. Will run it like that for now. Just gotta bleed n adjust the clutch. No idea how to do that and my help is gone today. Iím on my own
Posted on: 2019/8/3 21:52
3NE 2NR
From Melbored
congratulations, the first 4 speed someone has documented, keep it up
with this kind of detail and perseverance many can follow your efforts.
Posted on: 2019/8/4 2:25
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception unknown by dumb Aussies http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
Thanks bro. Itís running and driving. Shifts good even tho the bushings are shot(ordered new ones) and I think I need to bleed the clutch again. But itís a million times more fun to drive. Been driving it around all evening lol. Still got put a boot in it n do the wiring
The 4 speed is temporary. As soon as I can get a 5 speed itís out
Posted on: 2019/8/4 4:08
3NE 2NR
From Melbored
That's the spirit! whats the 5 speed from? suits the A series?
Posted on: 2019/8/4 10:46
B310 5 speed
Posted on: 2019/8/4 11:54
3NE 2NR
From Melbored
I take it all back! thought you were doing an Auto sorry!! :)
Posted on: 2019/8/5 5:11
Have to work on the clutch a bit. Have to bleed it again cuz it doesnít feel right. The release point is still a bit close to the floor and feels like itís an on/off switch when I step on the clutch. Not sure if Iím describing it properly. Also I see thereís an adjuster n lock nut on the slave cylinder. How do I adjust it properly?
Posted on: 2019/8/6 4:17
3NE 2NR
From Hawaii, USA
It is adjustment on both ends (first at transmission, then at pedal). The transmission end is same as 1200, adjust for 5/32" free play. Pedal height for b310 i dunno but it will be safe with 1" free play. If you don't have free play the clutch will wear out. see Hydraulic Clutch Adjustment
Bleeding is only needed for mushy pedal or grinding gears
Posted on: 2019/8/6 8:26
« 1 2 (3)
