« 1 (2)
Re: A15 crank wil NOT fit in A12 block
From Christchurch NZ
jpg  Capture.JPG (107.00 KB)
16379_5d77f2f8bce98.jpg 880X755 px
jpg  Capture 2.JPG (81.02 KB)
16379_5d77f37e55f60.jpg 514X717 px
jpg  Capture 5.JPG (64.22 KB)
16379_5d77f65ddabaa.jpg 475X696 px
Posted on: 9/10 20:03
jpg  Capture 3.JPG (65.50 KB)
16379_5d77f3a7db3a8.jpg 472X728 px
jpg  Capture 4.JPG (68.28 KB)
16379_5d77f3aeeb221.jpg 464X725 px
Posted on: 9/10 20:04
From Las Vegas USA
Thanks for posting the information and photos; I guess the title should read "will not fit without modification"
Very cool build.
Posted on: 9/11 2:57
No problems Rallytwit. I have probably got a little carried away but I'm excited to see how it all goes!
Posted on: 9/11 21:01
From Melbored
Can you reveal where on the rods and block hit the block or pistons?
Would spool rb rods do the trick or worse problem?
as I sometimes find a set of 5 on yahoo auctions.
Im still interested in doing a sleeved 79mm version for the mazda head
conversion on an A12 block oneday as the better flowing head will make
full use of the faster velocities of the rod stroke ratio.
Posted on: 9/13 7:39
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
See the minor scallops in the photo of the underside of the block? Those chamfers had to be a lot larger for the RB rods and broke through into the oil gallery. Unsure if a aftermarket RB rod would help or hinder. Would have to buy one or a set to see how they compare?
Posted on: 9/16 0:07
From Melbored
would need conrods that dont have the protusion on the rod bolt top area of the mains
eg.
http://4.bp.blogspot.com/-U5bKqqgO97E ... /s1600/connecting+rod.gif
will be interesting to see what you think of the bigger fatter torque area under the curve
eg. driveability etc. as Im sure no matter the head work, its going to have some serious
gas velocities with response normal long rod engines wont be able to match.
Posted on: 9/16 8:42
« 1 (2)
