WTD Front Axle lock nuts and washers.
From Sydney
Trying to locate these.
2 08114-06510 NUT-LOCK FRONT WHEEL BEARING (2)
3 40264-18000 WASHER-LOCK FRONT WHEEL BEARING (2)
It would seem they are no longer available anywhere. The real challenge is they the size is Metric Extra Fine M14x1.0 from what i can tell. Most fasterner stores look at you oddly as this is such an unusual size. M14x1.25 and M14x1.5 are common.
Posted on: 9/20 2:55
Edited by benny on 2019/9/20 6:34:19
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: WTD Front Axle lock nuts and washers.
From Hawaii, USA
Try Nissan 40262-18000 NUT-front wheel bearing
* Datsun 1000
* Datsun 1200
* Datsun 120Y early (1974-1975)
digging around it seems that Nissan USA has the wrong part number ... 0811 is a bolt per NES. The JDM catalog lists 40262-18000 which is a special part, a castellated nut
Posted on: 9/20 9:05
From Sydney
As an update. Sadly no joy with the genuine parts, however as an alternative, high tensile M14 x 1.0 thread is the standard thread on the modern freestyle bmx hub axle. I plan on machining the slots to create the “castle nut” for the split pin. Should be good to go from here.
Posted on: 9/21 3:04
1970 KB10 Coupe
S13 caliper b...
From Hawaii, USA
Some old adjusting nuts had holes drilled through for the cotter pin
The later Sunny used a plain nut with a sheet "castle"
Nissan 40263-U0100 CAP-ADJUSTING
* Datsun 610
* Datsun B310
* Datsun 120Y from 1975.10
* Datsun B120 from 1975.10
Posted on: 9/21 10:04
