datsun 60L dogleg striker lock pin removal
hi guys..
i am trying to remove the strike lever lock pin from 60L 5speed (dogleg)
For standard H pattern 60A, its easy to knock from the reverse check sleeve hole.
need help on the best way or a tool to remove the lock pin.
thanks
png  striking rod.png (25.93 KB)
17554_5d8663cc096a8.png 502X648 px
Posted on: 9/21 18:55
Re: datsun 60L dogleg striker lock pin removal
From Hawaii, USA
Here's the parts diagram
Looks like it is tapped out
* remove nut, washer & lock-washer
* using a drift, gently tap pin from Nut side
Because the threads are right there, be careful when using the drift
Can you post photos of this mechanism?
jpg  STRIKING ROD D32-04a.jpg (41.30 KB)
174_5d868c3596314.jpg 702X705 px
Posted on: 9/21 21:46
From Hawaii, USA
The diagram lists "O-RING" but I think it is a thrust washer???
Only the FS5W60L has it
Posted on: 9/22 0:17
From Hawaii, USA
Also the STRIKER has two pins & two nuts I think
1. Fastens BRACKET to STRIKING LEVER
2. Fastens STRIKING LEVER to striking rod
I have this photo of 56A 5-speed, it is similar although the BRACKET is much different
First remove bracket bolt, bracket, and pin
Then remove lever bolt, washers and pin
jpg  SHIFT ARM BRACKET (F5C56A) 0610-1.jpg (47.20 KB)
174_5d86b16354e7a.jpg 820X706 px
Posted on: 9/22 0:25
managed to remove it by tap with small hammer.
oring and oil seal are there.
ps: some photo i can only upload in gif file. poor quality
png  datsun.png (91.13 KB)
17554_5d870515b7919.png 1456X1088 px
gif  striker.gif (60.29 KB)
17554_5d870671ee072.gif 538X291 px
gif  oil seal1.gif (39.94 KB)
17554_5d870793a7d6f.gif 306X373 px
gif  oilseal2.gif (43.00 KB)
17554_5d8708257b573.gif 366X291 px
Posted on: 9/22 6:36
From Hawaii, USA
Those photos are very clear. They are small, but good quality. Thank you
Posted on: 9/22 10:02
thanks
Posted on: 9/23 6:44
