« 1 (2)
Re: Turbo sizes/models for A15 ???
From Hawaii, USA
Simon used for the A12 160hp he used GT2860R (707160-5) ball bearing turbo (stock part from twin-turbo Skyline) on E85. Stock block, stock head gasket, stock and unmodified H89 head
Posted on: 10/4 11:04
From Canberra
id be using a T28 turbo or larger for the 150kw..
Your injectors will need to be bigger we were running 23psi T28 on e85 with 750cc injectors to make 212rwhp with around 22 degrees of timing with A15 fully built, decent cam all big head work is where the power is made.
We gone to a GTX2871R that will be making the high 200kw range
My other engine is being built currently for the sedan, Fully built will be running 750cc injectors and just 98ron custom cam all head work 30cc chambers 5cc for headgasket 1mm headgasket ect ect ect
But is running a Garrett T25 and be into the 20's should see the 140-150kw mark is running a smaller clutch setup and the W50 not built behind it be happy around the 130-140kw at the wheels with that build
jpg  61926871_308022876778002_1340927689329999872_n.jpg (169.78 KB)
16063_5d9d8d0a9a178.jpg 692X519 px
jpg  62360531_10155908753891148_5897590469411471360_n.jpg (131.91 KB)
16063_5d9d8d1428d47.jpg 960X960 px
Posted on: 10/9 8:22
From Melbored
LK best engine datsun donk bay Ive seen
unlike many blue silicon hose ones which
look wack and dont suit these retro beauties.
what great persistence to get where you have.
Posted on: 10/11 0:59
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
« 1 (2)
