« 1 (2)
Re: 120y wheel offset
From melbourne
Yer right by the sounds of it the sizes i want maybe be abke to sqweeze in with a few mods.
Posted on: 2020/9/16 6:04
From Brisbane, Australia
This was with 15x8 +0 all round. Fronts poked a bit but didn't rub with the stretched 195/50s and 300lb springs.
Posted on: 2020/9/16 6:06
Edited by L18_B110 on 2020/10/8 5:04:28
From melbourne
With the back end was there much gap between the tyre and leaf spring?
Posted on: 2020/9/16 10:34
gap to the leaf spring wasn't an issue. I think you'd run into issues hitting the inner wheel well first on bump travel anyway, but that wasn't a problem either. Your issues are all going to be on the outside, but shouldn't be too hard with a stretched 175 or something...
Posted on: 2020/9/16 22:30
From melbourne
How do you find the 300lbs springs?
Are they to stiff or ok?
Theres a 45mm coil over kit with 12kg springs just dobt know if there to stiff
Posted on: 2020/9/19 12:34
300lb is about as heavy as people really go for track use on cars this light and R compound tyres. They were still OK on the street imo. The new owner went slightly softer for hillclimbs. 300lb is 5.36kg btw
12kg is absolutely insane for such a light car. It's far too stiff and would be totally crap at everything.
Posted on: 2020/10/8 5:14
« 1 (2)
