LED DRIVING LIGHTS
From Goulburn NSW
Hey Guy's
has anyone installed led lights on the 1200 datto?i am interested in doing this but are wondering how they would mount up.Can i use the original braketry for the oem lights?
Cheers.
Posted on: 8/27 2:34
Re: LED DRIVING LIGHTS
Iíve been thinking about it, but also a bit worried about fitting them into the original headlight buckets.
There are a lot of different LED headlights on the market now and Iím sure the quality varies as does the pricing.
I know member mrbarista has some fitted to his Ute. I also know you can buy fitting rings for the 7Ē lights quite cheaply if you search under Jeep LED headlights. The rings are plastic and I reckon you could get them to work (maybe with some minor mods).
Let us know how you go 🚘
Posted on: 8/27 7:22
From Hawaii, USA
For LED headlights, they bolt right in place using the Datsun factory 7" headlight rims (same as Jeep).
For off-road driving lights, who knows
H4 lenses with replaceable LED bulbs
Since LED uses less power than incandescent originals, the stock wiring works fine
Posted on: 8/28 3:25
From Goulburn NSW
Hey DD,
do you have a brand for the lights.
Posted on: 8/28 6:30
From Hawaii, USA
Those particular ones are the old generic "crystal" lenses, don't know if they still make em
Any H4 lens will do, including regular glass type. However the newer 9003 type lens will take either H4 or HB4/9003 bulbs, so that's what I'd get now search: 7" lens housing brands include Hella, EMPI, Narva, etc and can be bought on Amazon, eBay and your local auto or offroad performance shop
H4 with off-road mesh protectors
9003 bulbs are available in LED or Halogen. For example Philips Ultinon LED bulbs are $200 USD/pair, while cheap eBay specials are as low as $12/pair. The Ultinons are highly rated for longevity, brightness and patten/coverage. On the other hand with cheap units YMMV
Alo beware that HB4/9003 bulbs won't fit a genuine H4 lens. You can still buy actual H4 bulbs but here in USA the 9003(HB4) bulbs are much more common
You'll see "kits" advertised but only need the lenses & bulbs. Plugs right into the 1200 wiring harness, no kit needed. No relay needed. No CAN-BUS adapter needed :-}
Posted on: 8/31 9:21
Rigid Industries Trucklite 7" H4 LED
Posted on: 9/1 3:36
From Hawaii, USA
search: Rigid Industries Truck.lite 7" H4 LED
These appear to be sealed beams, not H4 (replaceable bulb) type. But they have an H4-compatible connector (actually the same connector as the original Datsun 1200 wiring harness connector)
* heated lens when temperatures drop below 50F/10C
* High Beam And Low Beam Functions
* Hard-Coated Polycarbonate Lens
* MSRP $574.99
* 3 Year Limited Warranty
* With H13 to H4 adapters (for new vehicles with H13 inline-pin connectors)
* USA DOT Compliant
* OPTIONAL anti-flicker module only needed for new vehicles with PWM lighting
* with a horizontal black piece that divides high beam and low beam compartments
* Replaces 6014, 6015, 6016, H6024 and Par 56 (Datsun 1200 came with 6012. The brighter one is 6014). This means it bolts up to any car with 7" round headlights
jpg  55001.jpg (86.43 KB)
174_612feb045ac64.jpg 1200X900 px
Posted on: 9/1 22:05
From Hawaii, USA
I like the idea of replaceable bulb lenses, because bulbs eventually fail (especially cheap LED bulbs - when they fail just buy another cheapo bulb or junkyard bulb)
Also you can buy lenses that have the RHD or LHD beam patterns
Those Truck-lites are good for countries where vehicles drive on the right. Although you could rotate the bulb by about 10 degrees by modding the headlight rings
In Europe where different countries vary, you can buy adapters to change the beam pattern when crossing a border. such as inexpensive stick-on masks (pattern adjusters/beam deflectors). This reduces the amount of beam light crossing the center line of the road
Posted on: 9/1 23:04
