Browsing this Thread:
1 Anonymous Users
Length-adjustable Rear Shocks |
Registered Users Contentmaster Usermaster
Yahoo AuctionsQuote: B110 リア フルタップ式 減衰12段 最大60mmショート可 B110 rear full tap type damping 12 steps Up to 60mm short is possible
国内の工場にて製造しております Manufactured at a domestic factory 工場の様子 State of the factory
Price: 54,500 Yen ($477 USD)
length adjustment attenuation 12 steps damping force 12-stage adjustment The damping force is 12-stage adjustable full tap shock, allowing for a wide range of settings. Lmin 250mm-330mm Lmax 365mm-445mm ストローク [Stroke] 115mm
Specifications * Lmin 250mm-330mm * Lmax 365mm-445mm * Damping Force 12-stage adjustment * Stroke 115mm Narrowest condition (Lmin)
It is possible to shorten about 6cmm from genuine shock.
Bushing and dust boots are also included.
Including the product of this place, you can use it with confidence because all the car height adjustment kit etc. of our handling are manufactured in The Country.
For repair, shock single item (20,000 yen tax excluded) can also be obtained. seller: ファインオートサービス [Fine Auto Service]
Posted on: 2021/10/26 23:42
Re: Length-adjustable Rear Shocks |
Stroke is limited. How would it work out?
Adjustable-length Shock Specifications
* Lmin 250mm-330mm [shorter than 1200 sedan (339mm), coupe (260mm), wagon/ute (288)]
* Lmax 365mm-445mm [longer than Coupe shock, but not as long as B110 sedan which is 506mm or wagon/ute 468mm]
* Stroke 115mm Narrowest condition (Lmin) [stock stroke is 167mm (sedan) or 180mm (coupe/wagon/ute)]
The bottom eye-mount for sedan is 12mm stud, coupe has 8mm stud. Easily modified for either
Posted on: 2021/10/26 23:56
