78 B210 A14 turbo build
From New Mexico
Using the stock manifold I made a turbo charge pipe that wraps under the engine mount ending up near where the charcoal canister was.
Posted on: 1/29 1:30
Re: 78 B210 A14 turbo build
From New Mexico
Trying to upload pics, not working yet
Posted on: 1/29 1:32
From New Mexico
If anyone has tips on a tune for a microsquirt v3 using a single injector that would be awesome!!
Posted on: 1/29 1:39
As I recall you can use one of the standard tunes for a single injector. Works well enough, though it won't have optimum fuel economy
Except ... with a turbo it is critical to have it spot-on, so maybe a standard tune is not a good idea with the turbo
TIPS on posting photos: see Photo uploads. The main thing is to use a small enough photo e.g. 1024x768 with 70% JPEG compression (file size under 200,000 bytes)
Or you could upload larger photos to a photo site, then link to them in your posts
Posted on: 1/29 8:40
From New Mexico
Good morning!
Does anyone know how to wire a Hyundai accent coil from a Bosch 0227100200 ignition module??
Iím trying to start my 78 b210 throttle body efi turbo setup.
Posted on: 4/11 13:34
