R31 radius rods alternative??
having trouble finding these so that I can do the s13 strut swap. any help is appreciated.
Posted on: 2/19 3:16
Re: R31 radius rods alternative??
S13 strut swap. If you are using S13 control arms, you can use S13 radius rods
Bezman did this with the bushing cut off, drilled 3" with a 1/2 bit, then tapped, used a grade 8 6" bolt with the stock B110 bushing and sleeve which allowed for lots of castor adjustment
Posted on: 2/19 18:31
thanks for the help man! I appreciate it
Posted on: 3/14 21:40
