4.11 Ring & Pinion (new); Used Dry Sump system
From St. Louis, MO USA
New in the box 4.11 ring and pinion for the H145 (38100-H1100) for $150 US.
Used dry sump oiling system with tank; lines; pump and bracket; crank pulley with drive mandrel; drive belt. Everything (bolts; brackets, etc.) except the pan (which was lost in a prior move but was simply a stock pan with 2 pickups.) $250 US.
New TDC Aluminum dry sump oil pan (use with above to complete the system??) $250 US.
Peter (please e-mail or call because I don't check the board too often). 314 291-8441 home or 314 724-7098 cell or PeterZekert@Juno.Com
Posted on: 2003/5/18 19:36
