Intake manifold needs a plate?
From Auckland, New Zealand
Hello all there again!!
Well thanks to all your tips i have removed my twin SUs of my cylinder head (all in one piece)
Now my second confusing problem is....
I am wanting to place an A14 intake manifold on the head now....
It has just the ol' single hitachi carb on it but i have noticed that it has no base just a big empty square on the under side of the manifold (i think it is supposed to recess into the original exaust manifold).
My problem here is ....
I don't have the original manifold i've got extractors?
Have i overlooked something really obvious here or is there some solution to this problem..
Thanks heaps in advance, all your help is really valued..
ConFused??
Kieran
Posted on: 2003/10/7 3:22
#Datopower#
Re: Intake manifold has no base?
I'm running a standard 1400 inlet manifold above a turbo. All we have done is made a plate out of 3/16 alloy sheet and made a gasket and it hasn't failed under 15psi of boost, so go for it.
Posted on: 2003/10/7 5:27
GO DATTO GO!!!
Hey Lsd...
Didi you weld this plate onto the manifold or did you bolt it on?? Just a few more pieces of information please??
Thanks heaps!
Posted on: 2003/10/7 20:58
#Datopower#
Just bolted it to the bottom of the manifold using the orginail bolt holes that went in to the exhaust manifold.
Posted on: 2003/10/8 5:21
GO DATTO GO!!!
