ca18 kits for 1200
maddat has engine x-member kits ( modified member & new mounts ) for $375
with exchange or $435 outright purchase.
at www.maddat.cjb.net see craig
Posted on: 2003/11/23 9:15
Re: ca18 kits for 1200
From Warwick, QLD
Talk to Andrew Denniss (CA18DET_MAN) about the crossmembers.
He does them for around $200 with mounts (exchange of crossmember)
Or $250 out right.
I have bought one off him and the engine sits nice and far back, perfect fit.
Cheers
Damo
Posted on: 2003/11/23 10:44
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Mudgee NSW Australia
Hey damo I also did on for Mildmans 1200 sedan in melbourne. I havnt heard how its going it was My latest version it sits 10mm of the firwall (same as yours) and 30-40mm lower than yours a fair bit more work as the crossmember has to be recessed to clear the sump. I have one in mine now even with the S13 5 speed in there I can get at the top of the gearbox bolts as it sits nice and low. Not to menchin the better weight distrubution.
Ill be up your way the 13th 14 december Im picking up My shortned LSD and also the R32 front brake setup to suit my stanza struts.
Give us a yell Im staying at toowoombah on friday night (my sister lives there) then heading over to Kev rowleys on saterday western suburbs brisbane
Cheers Andrew
Posted on: 2003/11/23 11:00
If In doubt run more BOOST
From T'ville
has anyone got thoughts on a alloy spacer between the xmember and the chassis rails to drop the a little lower , control arms would have to move, poss. bump steer?
any ideas if this has been done.
Posted on: 2003/11/23 13:29
