Wheel spacers
From Newscastle, Australia
Hi does anyone know where I can get wheel spacers and elongated studs to increase the track of the 1200 coupe? im in the Sydney area.
Posted on: 2003/12/22 10:44
Re: Wheel spacers
From victoria
How thick do the spacers have 2 be
Posted on: 2003/12/22 11:29
Re: Wheel spacers
From Canberra, Australia
The legalities of spacers are in a grey area.
I heard that as long as they are fixed to the axel or wheel.
(Screws, welded) then it is ok.
Because of the grey area. Alot of places don't sell them anymore.
If you want longer studs with the same thread then get some 240K type ones. (Check that out at the parts shop that you go to). If you want to go longer than that then you will have to change thread type unfortunately...
Posted on: 2003/12/22 12:17
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Wheel spacers
From campbelltown (sydney) australia
yer lobster is right, the ppl at bob jane told me they sell em, knowing thta they are illegal but as long as they are bolted either to the hubs or to the wheels they are considered legal, and for the simple job of doing this im sure its better than getting defected for.
Posted on: 2003/12/22 13:09
Re: Wheel spacers
The wheel track can be legally increased by not more than 2" or 50mm as far as i know.
You can do this with spacers, or you can do it with wheels. I recomend using the right spec wheels instead of trying to save a botched job with spacers.
The people at Bob Jane are not selling illegal spacers. If these spacers are used in an illegal way, on a registered car, then the person fitting them is comitting an offence. If they are used on an unregistered car, no offence is being comitted.
The onus is on the purchaser to use them in a lawfull way.
Posted on: 2003/12/22 13:13
Love your Datsun.
Treat it well.
Re: Wheel spacers
From Warwick, QLD
I've seen ARP bolts that were 2.5" long, then just get yourself a spacer for each wheel and then your talking
Cheers
Damo
Posted on: 2003/12/22 13:30
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Wheel spacers
Hello.
I am replying to this thread again, purely so that it will bump and people will see my new avatar.
Oh yeah as I said, the spacers thing is a grey area. Hence why some people will say yes and others no.
I'd talk to the proper authorities in your state about it. (RTA, engineer, etc)
Posted on: 2003/12/22 15:50
Re: Wheel spacers
From Warwick, QLD
Yeah I agree with the grey area but a cop ain't gonna pull you over and look under your wheels to see if you have spacers, they are too lazy, except maybe the shakers, but if you get into an accident then your in trouble. But don't get into an accident and your right. Its up to you cux you can get ride of spacers easy even if you get defected for it then when they remove the defect sticker you just put em back on.
It's like any mod you do can potentially be illegal, most cops don;t have a clue to small mods like this. But I'm just going off what I've seen it could be different round your way
Cheers
Damo
Posted on: 2003/12/23 3:22
Team NEW SKOOL
Re: Wheel spacers
From Melbourne, Australia
im pretty sure wheel spacers in any form are a definate no no on road but for circuit they are allowed if bolted/welded to hub
Posted on: 2003/12/23 4:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Wheel spacers
I should have mentioned its for track work only. I did have another coupe which had spacers and they deemed legal. Ok heres the senario...I have a ute diff and with the current race wheels, they fit snugly within the std lipped rear guard. What I want is to keep the ute diff and increase the track (inproves handling) to around 50-60mm each side so about 120 extra track in total on the back. This will fit within the legality of 50mm guards for IPRA.
So what 13" diameter wheel with what offset should I go for???
Posted on: 2003/12/23 7:10
