Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
comp ratio's?
1000wags
Posted on: 2004/5/28 14:28
I was wondering if anyonew knows a link to a site to work out comp ratio
I will soon be building a engine for my wagon i was thinking A14, a15 pistons and the h72 low comp head, with a 4agze supercharger. don't really won't to run a head shim, but wont to get the comp as low as possible. i've thought bout a15 with a14 crank but can't register with the a15 any other idea's ? cheers
#2
Re: comp ratio's?
phunkdoktaspok
Posted on: 2004/5/28 16:09
I know its not an answer to your question, but why cant you register it with an A15 but yet you can with a supercharged A14?
#3
Re: comp ratio's?
tsillay
Posted on: 2004/5/28 22:04
Hey yup.
the C/R is determined thus Capacity of one cylander+capacity of the headgasket+capacity of the combustion chamber (+ or - any piston dish or pop top) divided by Capacity of the headgasket+capacity of the combustion chamber (+ or - any piston dish or pop top) So, for example... a 1608cc engine with a bore of 80mm and a stroke of 80mm, a 1mm thick headgasket (5cc) and a 40cc combustion chamber running flat top pistons.. 402cc+5cc+40cc+0=447cc divided by 40cc+5cc+0=45cc is a C/R of 9.3:1 hmm, might actually be 0.5cc, could have a decimal in the wrong place but you get the idea!!
#4
Re: comp ratio's?
nzdatman
Posted on: 2004/5/29 0:20
plus of course the volume between piston crown at TDC and top of block if pistons don't come right to the top, which when you're aiming for low comp is highly likely.
#5
Re: comp ratio's?
A14force
Posted on: 2004/5/29 7:38
Using a15 pistons in an a14 is the same as putting an a14 crank in an a15, (same conrods, different pin height)
I was going to go down this road, but after giving it more thought, and speaking to an engine reconditioner, I now think that a better trick would be to get the a15 pistons, (in an a15) and machine the eccentric dish so that it is concentric, but still leaving the squish ring in place. This will lower compression enough to allow for the type of boost you would likely create safely with a 4agze s/c , without completly sacrificing the motors off boost power.
#6
Re: comp ratio's?
1000wags
Posted on: 2004/6/1 7:35
phunk
it won't be legal but atleast i can pull the charger off if need be to make it legal rather than an engine change cheers for the info fella's
#7
Re: comp ratio's?
Rogue
Posted on: 2004/6/2 1:34
Great formula for comp. ratio !
Although I do have a question relating to this topic. What would be the maximum compression ratio that you could run with LRP (lead replacement petrol) in an A14 without having a cranky pinger of an engine ? This is assuming that the motor is fresh & well tuned, electronic ignition & a decent exhaust system. edit: If not LRP what about 98 octane Premium? Any opinions would be appreciated. You can view topic.
