#1 What bits do you need for a single 42mm sidedraught webber?
SILVERBAK Posted on: 2004/8/19 1:52
If i had the manifold and carby what else do i need to get it fit?
#2 Re: What bits do you need for a single 42mm sidedraught webber?
evilsim Posted on: 2004/8/19 7:47
you might need the linkage kit for your weber. if so - get a linkage kit which matches your inlet manifold. apart from that just some spare fuel line hose might be needed.
the linkage kit is good as it has new rubber spacers for between manifold/weber and a few other bits which are required.
goodluck
