Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
how strong is a H190
C_A_R_I_D_I
Posted on: 2004/10/8 11:23
hey everyone,
i am just looking for some reconmendations on a diff for my 1200 sedan that will be able to handle around 196 lb-ft@ 3500. i will be running a five speed. i was thinking a H190 will this be able to handle this sort of power with ease or should i be looking for mabye a r31 LSD? im trying to keep price in mind cheers frank
#2
Re: how strong is a H190
1200rallycar
Posted on: 2004/10/8 15:52
they can taker a fair whack of power
my bro-in-law always tells me of an rx-7 drag car using one, apparently it has around the 500hp mark, but unsure of torque sorry
#3
C_A_R_I_D_I
Posted on: 2004/10/9 0:28
thanks mate,
196 lb-ft@ 3500 thats the torque of a standard 200hp 13b turbo (which i want to run) so it should hold up for years. cheers Frank.
#4
feral
Posted on: 2004/10/9 1:02
There is one that comes into the dyno I use in a 910 Bluey with FJ20T. The car has 280 Rear wheel kw's.
It has never given trouble even with nasty abuse, such as side stepping the clutch at about 5000
#5
Posted on: 2004/10/9 17:15
190mm is equivalent to 7.5 inches. The Ford 7.5 rear is good for 285 lb-ft of torque (based on its use in the 1984 Mustang GT 5.0).
With only 200 lb ft, you could use a lighter differential gears like the H165, however the H165s have too weak of axles (?) to handle the torque???
#6
MadTimo
Posted on: 2004/10/10 2:25
Yeah, I agree.....H190 is probably too big. We run a Ford 7.5 on a 430 rwhp RX7.
But at least you know it will never break I guess. If you are using a series 4/5 turbo gearbox as well, there's no way you'll ever break anything.
#7
C_A_R_I_D_I
Posted on: 2004/10/10 10:09
i think ill go h190 now instead of later.
i think ill run the s4/5 box for now but upgrade when power eccedes its limits. cheers Frank
#8
MadTimo
Posted on: 2004/10/11 4:06
If you run a S4/5 gearbox, you won't need to upgrade for a long time, trust me
#9
L18_B110
Posted on: 2004/10/11 6:36
196 lb-ft@ 3500 thats the torque of a standard 200hp 13b turbo I'd double check that if I were you. is that a rear wheel figure? If its correct, I'd agree that a H190 is overkill. A H165 or 120Y/Corolla Borgwarner will handle that.
#10
C_A_R_I_D_I
Posted on: 2004/10/11 7:56
well if a 13b has more torque than a CA18 det and a h165 has trouble handling it with a few mods added wouldnt it be better???
and ill upgrade gbox when i want to instead of upgrading g'box and diff again. better spend the money now than later. cheers frank You can view topic.
