#1 weber bolt patterns
cabridgee Posted on: 2005/1/3 2:53
Does the DCOE and IDF weber have the same bolt pattern as a 32/36 carb? if so, with an adaptor (and all the mods needed for fitting a 32/36) could i use a IDF carb?
#2 Re: weber bolt patterns
cabridgee Posted on: 2005/1/3 6:47
Urgent!! a friend is offering me a 40 IDF weber, used on his dads a 4cyl. torana, he's offering it to me for $200, and would need to know if i would need a new intake manifold for this carb?
#3 Re: weber bolt patterns
ang94541 Posted on: 2005/1/3 8:27
the horizontal ones are DCOE's, the vertical ones are IDA's or IDF's.
It would take an interesting adapter and possibly a hole in the hood to get an IDF to fit.
I'll scan and post something regarding bolt patterns.
#4 Re: weber bolt patterns
ang94541 Posted on: 2005/1/3 8:35
#5 Re: weber bolt patterns
cabridgee Posted on: 2005/1/3 9:51
looks like i will have to find a new intake manifold for it QUICKLY or i will have to let this oppurtunity slip up
#6 Re: weber bolt patterns
nicholas Posted on: 2005/1/3 13:35
i've got a 44 idf that i want to bolt on to my 1400, but i've had a manifold made up, looks good and works well. what motor is that in the pic?
will post pics of it soon for you to get some ideas
cheers
#7 Re: weber bolt patterns
cabridgee Posted on: 2005/1/3 21:12
is the manifold a modded stock one or a custom job? could you post some pics please
#8 Re: weber bolt patterns
nicholas Posted on: 2005/1/4 6:02
modified stock on, works great lots of welding to do though, i'll try post pics by the weekend
