Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
1200 Sedan Fuel Tank Query????
Maz
Posted on: 2005/3/22 0:39
Hey all. Be needing some help on this one.....
Can i, or has anyone from here used the original tank in a 1200 sedan for EFI. There is, naturally 1 feed off the bottom + 2 breathers on the top. Can one of these breathers be used for a return???? I will have a surge tank in the boot. As long as the fuel tank still has 1 breather i'm hoping this is do-able...
#2
Re: 1200 Sedan Fuel Tank Query????
jozz
Posted on: 2005/3/22 1:13
Hey, yeah ive done it, i used the standard 1200 fuel tank with efi, with my CA Turbo and its fine. Ive got a surge tank and yeah i used one of the breathers as a return, should be no problems.
Cya
#3
Maz
Posted on: 2005/3/22 1:54
Thanks Jozz.. Your a champ... Saved me forking out for a new tank. Did you vent the other one back to the filler as standard or outside the boot? I was thinking of just t-piecing it and doing both..
#4
converted
Posted on: 2005/3/22 2:10
Even so I bought an RCI tank from Rocket which is foam filled and h/d plastic (impact resistant for $200
#5
jozz
Posted on: 2005/3/22 2:12
Ill have 2 check that one out, im at work at the moment, so ill let you know when i get home, but the t piercing sounds like a good idea...
