#1 A14/A15 GX Oil Pump: difference Vs. standard A14/A15?
Yokohama Posted on: 2005/4/8 21:10
I have seached for this, but all I could find was talk on the Nismo pump.
I would like to know if there is any difference in volume/pressure between the A14/A15 GX engine oil pumps and the standard A14/A15 oil pumps.
I would not think there would be since it's not a race spec motor or turbo.
Thank you.
#2 Re: A14/A15 GX Oil Pump: difference Vs. standard A14/A15?
BigV Posted on: 2005/4/9 4:03
If you go to your local nissan dealer and ask about an A12gx oil pump they should be able to tall you if this is a different part number this would be a start
I just run a washer under the bypass spring for a little more pressure
