Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
coupe grill
Posted on: 2005/6/8 10:08
does anyone know how to fit the metal sedan grill to a coupe (i hate the plastic grills)
i notice the mounting pints are different for some stupid datsun reason. Has anyone else done this? i also notice the headlight eye brows dont it as well......... why datsun why!
#2
Re: coupe grill
Freak
Posted on: 2005/6/8 10:53
Yeah sedan grills have only got 5screws + the headlight surrounds whilst the coupe is like 8. My sedan when i bought it had a coupe plastic grill. To fit this the bloke just pot riveted little brakets in the right spots. You could do the same but the other way around.
#3
Re: coupe grill
Posted on: 2005/6/8 11:01
was thinking that or just drilling grill to fir existing brackets, but with the sedan grill on the coupe, the eyebrow surrounds dont fir as well.
#4
Re: coupe grill
dazzasute
Posted on: 2005/6/8 11:06
i got a sedan grill on my ute no problems. for the grill itself, i just got some 30mm gutter bolts, and drilled 4 holes in the panel behind the grill. its not tight, as there's a gap in some parts between the grill and the bit behind it. i just put double nuts on the bolts to stop them coming loose. mount the eyebrow's first. just drill holes where its supposed to go.
oh, and i like your taste... looks much better!!!
#5
Re: coupe grill
Posted on: 2005/6/8 11:16
i was thinking also threaded rod with double nuts and washers, same as the gemini radiator setup but with wing nuts on the inside.
1200rc prefers the coupe grill though.... i think the metal looks nicer. will try over the weekend.
#6
Re: coupe grill
Freak
Posted on: 2005/6/8 11:43
metal is alot better. Plastic just looks cheap and is too modern looking for a 1200. Chrome and polished stuff is old skool bling.
