Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
LSD solution?
D
Posted on: 2005/6/22 11:17
Would it be possible to make a machined billet centre casing for a common lsd centre as that found in 200sx and other independant rear ends but to suit a live axle setup with bolt on axle tubes? similar to this one on the link? Then with custom axles (the second most expenive bit) and using pintara brakes wed have a strong lightweight diff with many common lsd centres to play with. Common any ideas from anyone for something similar?
http://www.franklandracing.com/liveaxle.htm http://www.wintersperformance.com/catalogs/2005WintersPerformance/0161024.htm
#2
Re: LSD solution?
feral
Posted on: 2005/6/23 2:01
There is an early Alfa axle like this. You can get them with LSD for about $1200 but the axles have to be modded a lot and this is expensive.
Billet centre housings are used for sports sedans/ circel track cars, using ford 9" centres with independent axle set ups. They cost !~!!!!
#3
Re: LSD solution?
Coops
Posted on: 2005/6/23 5:53
What are you trying to do here...... Go to a 25 spline axle to save weight?
The 28 spline axle out of a R31 skyline is what I'm using. It's pretty light (comparatively speaking), strong (will handle 220 hp no worries), cheap ($180 from the local wreckers) & all you have to do is get 1 axle shortened & insert a LSD centre from an EA / EB Falcon. Plus you get to use the skyline disc brake rear end.
#4
Re: LSD solution?
D
Posted on: 2005/6/23 10:29
Yeah the r31 skyline setup is cheap and seems to be very popular. I was looking at something like these setups which are supposed to be 24kg complete with the 7 inch mini billet centres that can handle about 250hp. In the end Im looking at possibilities of going just under 540kgs.
#6
Re: LSD solution?
D
Posted on: 2005/6/24 10:33
#7
Re: LSD solution?
datto_dave
Posted on: 2005/6/25 1:13
a friend of mine is converting my diff to lsd for $350
#9
Re: LSD solution?
Ash
Posted on: 2005/6/27 3:20
by Coops on 2005/6/23 15:53:12 Why do you only shorten one axle? Won't that put things off centre? I'm very interested in using an R31 diff in my car
#10
Re: LSD solution?
B120dat
Posted on: 2005/6/27 4:51
Datto_dave you have a good friend
does he need another datto friend ??Is he converting the H165 diff to LSD? i am intrested You can view topic.
