Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Strut Upgrade
Nissan4Eva
Posted on: 2005/7/28 17:25
I got some struts of a datsun laurel recently and want to put them on my 1200. wat bottom ball joint and rod end will have to use so it works with the new struts steering arms??
![]() ![]() ps..they look very much like Z struts. The idea is to use the longer bottom arm with modifications for the new bolt on ball joint etc... how long would the bottom arm have to be a achieve around 4-6degrees of negative camber??? front tyres are 7" wide. ![]() ![]() thanks.
#2
Re: Strut Upgrade
Nissan4Eva
Posted on: 2005/7/29 3:32
cha...24ppl viewd this so far and no one knows the parts needed
#3
Re: Strut Upgrade
LAGWAGON
Posted on: 2005/7/29 4:00
its a bit of a weird request mate. who has a laurel, let alone wants to put its brakes in a 1200?
use simple trig maths to work out how much extra length the arms need to give you the camber you require. in my experience 8-10mm is one degree. good luck!
#4
Re: Strut Upgrade
Nissan4Eva
Posted on: 2005/7/29 4:54
8-10 seems about rite, i did 16mm redrill on my escort Xmember and got 1.5 extra negative camber....
Well What bottom ball joints do u guys use when using 240z struts etc. You can view topic.
