#1 What compression ratio do i have?
MattoRX7 Posted on: 2005/8/21 3:18
i have a stock A14 bottom end out of a sunny wagon and a A12GX head with 2.5mm shaved of it. what compression do i have? also what piston could i use to get my compression to about 11:1 ratio?
#2 Re: What compression ratio do i have?
BigV Posted on: 2005/8/21 4:46
id say lots
#3 Re: What compression ratio do i have?
Dats-hot Posted on: 2005/8/21 8:21
Why use a small valve head on the A14 engine? The a14 and a15 heads used bigger valves than any 1200 head.
#4 Re: What compression ratio do i have?
killer1200 Posted on: 2005/8/21 15:57
For more compression.I'd say about 10.3-10-7.
#5 Re: What compression ratio do i have?
Coops Posted on: 2005/8/21 23:09
I don't know what piston, but I'd suggest avgas or some other racing fuel for that comp or it will be pinging its tits off.
