#1 120y Springs
muppet Posted on: 2005/9/15 5:01
Are the B210 and B310 front springs interchangable and are one of them longer than the other?
#2 Re: 120y Springs
Keith Posted on: 2006/1/2 11:09
I put some b310 springs in my b210 struts today and the car is riding high.
Maybe I overlooked something as I thought the springs were the same length, strength, and diameter.
anyone done this swap?
(b310 springs into a 120y)
#3 Re: 120y Springs
Dodgeman Posted on: 2006/1/2 11:14
If you thought that they were the same, then why swap them?
#4 Re: 120y Springs
Keith Posted on: 2006/1/2 20:26
They weren't rusty....
#5 Re: 120y Springs
b310gx Posted on: 2006/1/3 2:22
id say the sunny springs are longer,as the sunny struts are the longest of the lot.so get out the wire brush & some cheap spray paint, flat black or otherwise & recondition them.
#6 Re: 120y Springs
Keith Posted on: 2006/1/3 3:18
The tech section here says that the b310 springs are actually shorter than b210 springs.
#7 Re: 120y Springs
PIGDOG Posted on: 2006/1/3 6:22
from memory the sunny springs are half way between stanza and 120y, or somewhere near there
sunny ones are definatally longer
#8 Re: 120y Springs
sam1741 Posted on: 2006/9/9 11:37
according to the tech section..
http://datsun1200.com/modules/nsectio ... p?op=viewarticle&artid=68
b210 front coil spring
free length = 375mm / 388mm (w/ac)
b310 front coil spring
free length = 381mm / 375mm (A12A)
this making me confused.. :(
as i thinking getting 240z spring into my b310,
cause i read that B310 and B210 strut is the same,
and someone is using 240z spring with cutting out one coil for their B210 strut..
#9 Re: 120y Springs
dreamers_vault Posted on: 2006/9/12 5:22
i've the solution...check it out..u know where right?
#10 Re: 120y Springs
ade Posted on: 2006/9/12 8:42
yes mate I have swapped them after I had them very nicely powder coated and the phucking car looked like it was running up hill so out they came and two coils removed.
ask tappet how it rides now
cheers ade
