Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Torquemeister A15?
vex66
Posted on: 2005/10/8 16:34
I have collected various bits & pieces to build an A15 for my sedan & was wondering which combination will best suit my purposes. I want torque rather than outright horsepower & although I am not really worried about fuel economy, I don't want it to waste fuel. I have an A14 oval port head (rebuilt) but twin 40ml Dellortos on a round port manifold. I already have extractors on the A12 & apparently the head has had a bit of work but probably needs rebuilding. I was thinking that the A15 with a mild cam, round port head, twin dellortos & extractors would be a good combination in a street car. By the way, luckily someone has fitted a late model A12 so the engine mounts have already been modified.
#2
Re: Torquemeister A15?
matbighat
Posted on: 2005/10/8 17:19
Don't be vexed, but you're going to need to find an oval port intake to go with the A14 head.
#4
matbighat
Posted on: 2005/10/8 17:26
Doesn't make much sense to choke the larger displacement block with a small port head. Even the factory didn't do it. Just don't go hog wild on the camshaft if you want torque vs. rpm hp.
#5
vex66
Posted on: 2005/10/8 17:31
Yeah, I was just curious to see if anyone had done it & what it ran like. The cost will probably be much of a muchness as I either have to buy a manifold or rebuild a head. I have to pull the head off the A12 to see if it's got bigger valves fitted.
