#1 Ignition interferes with the TV- missus not happy
Grunterhunter Posted on: 2005/11/10 4:27
I have just upgraded to one of those GT40 solid state coils (squareish looking rather than cylindrical like a normal coil) and now you can see each cylinder firing as a line accross the tv screen.......
hmmmm might be useful for tuning
Does anyone know what might be going on here? Are the leads not coping with the extra spark form this type of coil or is it related to the ballast resistor?
(it said to retain the ballast resistor on the installation instructions)
any help would be appreciated
#2 Re: Ignition interferes with the TV- missus not happy
BACKFIRE Posted on: 2005/11/10 6:15
Where is the TV in relation to the coil? As in, either side of the fire wall? Or in the garage vs. in the Boudoir?
(Assuming they are both in the car...) If it is like a radio it could be the grounding of either or both, or the telly electricals may need a filter.
But I'm no bright spark.
#3 Re: Ignition interferes with the TV- missus not happy
COUP1200 Posted on: 2005/11/10 6:34
Its normaly leads that causes it. The leads will need to arcing out for this to happen. Check under the bonnett in a dark place to see if the leads are arcing out.
Coops
#4 Re: Ignition interferes with the TV- missus not happy
boofhead Posted on: 2005/11/10 6:38
on a side note - with the small GT40 coil, watch out for it over heating if you give it a real hard time. once it stops, thats it, you're staying where ever you are till you get a new one i've had it happen a while ago and after asking around decided to stick with the oil filled cylinder as they self cool better.
p.s : try moving the car out of the lounge room .... might help with the interferance on the telly
#5 Re: Ignition interferes with the TV- missus not happy
Grunterhunter Posted on: 2005/11/10 7:09
errrrrrrrr yeah- I should have specified. There is not and never will be a television, playstation, italian leather steering wheel, neon lights or blue arse fly paintjob in or anywhere near my car Sincerest apologies to anyone who thinks those things are important, and have looked at this thread in the expectation of seeing a tv equipped 1200. I have the deepest sympathy for you, and anyone you choose to share these lame fantasies with
Anyways, the TV in question is in the living room, under the same roof, about 7m away. (the car is in the spare bedroom not the loungeroom )
I'll have a look for arcs, thanks for the suggestions.
#6 Re: Ignition interferes with the TV- missus not happy
Posted on: 2005/11/10 22:26
whats wrong with a blue paint job... my utes blue :(
i gues you have to sleep with the car then in the spare room, at least not in the dog house
#7 Re: Ignition interferes with the TV- missus not happy
COUP1200 Posted on: 2005/11/10 22:51
Those small GT40 coils dont like vibration or heat.
Grunterhunter.
Make sure you you mount it away from the motor. You are better off with a oil filled GT40 coil as they cool heaps better.
Coops
#8 Re: Ignition interferes with the TV- missus not happy
Grunterhunter Posted on: 2005/11/11 1:24
cheers coop, I'll see how it goes- the car starts better, but no noticeable performance improvement. no arking out anywhere, I checked last night.... might have to keep the old one in the glovebox for emergencies!
Unfamilia- I have no problem with blue, a nice dark blue looks great on 1200's. I was referring to "Blue arse fly" also known as purplelooza- bright metallic blue to purple to green to gold paint jobs that scream out "hey look at me, I have no taste"
#9 Re: Ignition interferes with the TV- missus not happy
sunny Posted on: 2005/11/11 1:50
I agree totally, I also think that lugging around 30kg of stereo gear is for the "look at me tossers"
Dooff Dooff Dooff
absolutely nothing wrong with radio nissan had as an option!!!
#10 Re: Ignition interferes with the TV- missus not happy
dattodevil Posted on: 2005/11/11 6:57
Use decent suppression leads with NGK resistor plugs and your problem will be gone
