#1 SR20 in 1200 Race Car....which Radiator???
converted Posted on: 2006/1/2 0:09
Hey just need a few suggestions as to what radiators people are running with their SR20 powered 1200's.
Im after economy in price, lightweight, and excellent cooling capacity as well as easy fit.
I am also running a large oil cooler as well as a winged, baffled and finned alloy sump to keep oil temp in check.
#2 Re: SR20 in 1200 Race Car....which Radiator???
Ronald Posted on: 2006/1/2 0:28
Auto Sport Engineering in Adelaide might be able to help you out. they make custom intercoolers and radiators by request.
ASE
other than that, i'm not sure if there are any bigger than an A15 radiator that would fit in easily.
here's one with a CA18DET with a custom radiator. i think it says Mr. Enforcer Engineer on it.Luke's CA18DET Ute
this is a 1600 with a custom radiator.
Adam's SR20DET 1600
it has stuff about the radiatpr right at the top of the page.
hope this helps
#3 Re: SR20 in 1200 Race Car....which Radiator???
datman55 Posted on: 2006/1/2 0:29
Hey Craig........
A pulsar radiator should do the job. Itkeeps mine under control, so it should be fine for yours. Justin also uses the same thing - very light too.
Are you back at work this week or on Hols? I need to come over your way sometime this week.
Mark.
#4 Re: SR20 in 1200 Race Car....which Radiator???
converted Posted on: 2006/1/2 0:56
Back at work on the 3rd Jan darn it...
I'll have a look at the pulsar radiator...
Mark can you please give me the dimensions of it and also where the outlets are located?
#5 Re: SR20 in 1200 Race Car....which Radiator???
Razor Posted on: 2006/1/2 1:24
how hard is it to install pulsar radiator?
just new radiator bracket?
cos they have it on the top/bottom of the radaitor instead of the side bracket like the datsuns
#6 Re: SR20 in 1200 Race Car....which Radiator???
converted Posted on: 2006/1/2 1:27
mmmm......I think the outlets are the wrong way around
I need looking into the engine bay the right of the radiator for the outlet to be at the top right and the outlet on the left to be at the bottom or mid point.
#7 Re: SR20 in 1200 Race Car....which Radiator???
flyby Posted on: 2006/1/2 3:15
there are two types of n13 radiators, the import version has outlets on the same side.
Basically you can not get a bigger (wider) radiator in there, nice and light too.
#8 Re: SR20 in 1200 Race Car....which Radiator???
flyby Posted on: 2006/1/2 3:16
easy, install the bottom mounts the n13 has or similar and make up/modify the top brackets
#9 Re: SR20 in 1200 Race Car....which Radiator???
phunkdoktaspok Posted on: 2006/1/2 3:54
AFRacer uses a 180sx radiator, But I notice his top hose comes from the engine differently.
#10 Re: SR20 in 1200 Race Car....which Radiator???
datman55 Posted on: 2006/1/2 7:00
Craig, I have mine out at the moment and I need to come over your way this week sometime. I'd be more than happy to bring the radiator with me for you to check dimensions etc. It does seem though that the outlets are in the wrong spot.
Mark.
(1) 2 3 »
