Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Clutch Master Cylinder Setup on 1200 Ute
1200_ute
Posted on: 2006/1/5 2:25
Hi
I need to put a hydrolic clutch on my 1200. Just wanting to know if any one knows what master cylinder to use? If u got pics of your setup they would be great. Thanks in Advanced Mitch
#2
Re: Clutch Master Cylinder Setup on 1200 Ute
B120dat
Posted on: 2006/1/5 2:43
Hey mate.... it isnt a easy or hard to setup hydrolic clutch up, more of a headache
But there are various ways you can you a Urvan internal setup, or inbay setup. I used a inbay setup with a new 180b clutch clyinder. I put mine next to my brake masters because the wall there is extra stong and doesnt flex and then i could use my stock clutch. I cut a hole there (which is quite tight measure twice ) then i had to mod the linkage so it was alot shorter, then lined up straight with my pedal and drilled the hole.Other options are the under dash (Urvan internal) and using a s1/s2 bluey pedal mounted left of ur old pedal with the clutch master setup. I have pics of my setup i will post on 1200.com and put a link no here for ya Link to pics: http://datsun1200.com/modules/myalbum/photo.php?lid=7742 http://datsun1200.com/modules/myalbum/photo.php?lid=7741 P.s but if you are using a Ca18det or another motor in ur 1200 this may require a much different setup!!... the CA owners would know.
#3
Coops
Posted on: 2006/1/5 2:46
For CA or SR setup: -
Grab yourself a clutch pedal assembly from either a R31 skyline or similar year pintara. Make sure you get the little bracket that seperates the clutch pedal / spring ass'y from the firewall. It'll just be spot-welded on. Then it's just a case of drilling the appropriate holes in your 1200's firewall. You will need to brace the pedal / spring assembly as the firewall isn't rigid enough to support it (don't forget that little bracket), but this should just be a matter of bending up a bit of 5mm strip & drilling a couple of holes to affix to your steering column. You can view topic.
