Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Compression Depression
dattodude
Posted on: 2001/1/10 7:50
Hey Guys, I just did a compression test and I'm amazed with what I found. Expecting between 150-175psi based on previous experiences:
Results (dry): 1: 150psi 2: 125psi 3: 100psi 4: 130psi At first I thought it could be head gasket...until I did the oil in the cylinder trick, to check for possible worn compression rings. Results 2 (oil added) 1: 175psi 2: 150psi 3: 130psi 4: 150psi Looks like my CA18 has buggered compression rings. Even though it's not blowing much smoke, appears I could be losing up to 40% power through lack of compression. The little smoke I do see out the back is probably due the fact that the low compression is not burning all of the petrol resulting in petrol smoke. So it's time for a trip to SSS Autos for either a new engine, or a cheap short engine for a mega rebuild. I always thought there wasn't something quite right. I'll keep you all posted. You can view topic.
