#1 1200GX 120Y
mitey1200 Posted on: 2006/6/6 2:08
My mate has just got a Datsun 120Y that has been in a small crash. He said i cud strip it down and take the parts i want. I was just wondering if it wud be worth taking the head off and putting it on my Datsun 1200 coupe? i heard the GX had different valve ports?
#2 Re: 1200GX 120Y
Dodgeman Posted on: 2006/6/6 2:18
Has your mate got an original 120Y GX, or a GX engine in his 120Y?
The GX engine came with factory twin carbs & a special exhaust manifold, & to top it off, the method of geting oil to the rockers was changed when they reviewed the design of the engine for 1974, so a small modification is needed when using the later heads on a 1200 block.
If he has a 120Y GX engine, then by all means use the head, complete with the twin carbs & exhaust manifold. You'll love it.
Oh yeah, the GX also used a hotter cam, so it might be easier to switch the whole engine into your car.
#3 Re: 1200GX 120Y
mitey1200 Posted on: 2006/6/6 3:16
Well its a original GX 120Y but it only has a single carb so it must of had an engine transplant at sometime from just a normal 1200? thanx 4 the reply
#4 Re: 1200GX 120Y
rb20 Posted on: 2006/6/6 6:15
the gx head will have ovel shaped ports and double valve springs
#5 Re: 1200GX 120Y
Dodgeman Posted on: 2006/6/6 6:22
Check the number on the engine against the engine number on the tag in the engine bay. This will tell you if it is the original engine.
If it is a genuine JDM GX car then it is quite possibly worth saving as these were special little cars & you did say that ti was only a 'small' crash.
See if you can post up a picture of the car & the dash panel with instruments.
#6 Re: 1200GX 120Y
mitey1200 Posted on: 2006/6/6 10:57
Well i guy gave it 2 him 4 free cos he apparently had fallen asleep at the wheel and crashed in2 a ditch. the left front has been pushed in. I scabbed a few bits like the sway bar and mirrors.
