Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
datsun 1200 sedan project
ca18_sedan
Posted on: 2006/6/12 3:55
I have gradually become disoriented with the whole project thing. So I've decided to buy some more property.
Datsun 1200 sedan Fresh 2K paint - custom colour with gold ice pearl, took 6 months of prep work. Requires a buff job. will supply the painter to finish it as part of sale. Freshly built ca18det, not started as yet. cost $1700. RB20 5 speed, 3400lbs pressure plate and new clutch. r31 skyline diff - 4.11 rebuilt lsd Front coilovers - modified stanza struts. (come with new ball joints, tie rod ends, rebuilt calipers and machined disks) Microtech Lt10-s, x4 ignition module, bosch coil packs - Brand new, programmed for ca18 600x300x75 intercooler new 200sx radiator rx7 front seats with modified rails to fit car 14 x 6 performance super lites, vgc falken tyres HKS T04E turbo kit manifold, wastegate etc. Full autometer dash, liquid filled pro-comp gauges. Custom retrimmed dash, currently at trimmers now. Turbosmart dual stage boost controller Turbosmart plumback blow off valve Zex nitrous kit Bosch electric fuel pump - 400hp 550cc rx7 injectors - cleaned and flowed Full set of brand new rubbers - over $700 worth Set of TRX rims Pivot turbo timer - brand new CYA 18 personalised plates There is probably more but I just can't think of it all now. Requires to finish: Exhaust and intercooler piping hoodlining, carpet, door trims mod plate, rego wire mictrotech and tune - comes with wiring diagram It currently owes me over $20k and I just can't justify pumping out anymore money to finish it off, so I want it gone. I don't want to split it up, but may do so if I get enought interest. $10,500 or nearest offer. Datsun photo's
#2
Re: datsun 1200 sedan project
LAGWAGON
Posted on: 2006/6/12 4:31
wow, thats quite a setup! if i can give you some advice... split it up a bit and you'll sell it quicker and get more. thats my experience anyway.
and on that note, whats the nitrous kit, what have you got with it is it a single fogger sys etc and if you split your gear up how much do you want for it? good luck with the sale mate!
#3
ca18_sedan
Posted on: 2006/6/12 4:42
I thought about splitting it up, but I wasn't sure how much of it would actually sell. The nitrous setup is just a dry system but is missing the solenoid, I was throwing it in with the car as I have no use for it. I'd probably want $400 for it separately.
Ok a bit of a break down on what I'd be wanting to split it up. Car - with diff, 1200 struts, wheels, full set of rubbers, ca18 modified crossmember, intercooler, radiator, etc. - $4500 Coilovers - With rebuilt calipers, new ball joints and tie rod ends - $700 Ca18det - rb20 5spd, machine work, new rings and bearings, 3400lbs clutch pressure plate and HKS T04e, microtech - $3800 Autometer gauges - procomp memory recall tacho, procomp 160mph speedo, liquid filled procomp oil, water, boost gauges, fuel level, nitrous pressure - $1000 rx7 seats with rails - $450 All other miscellaneous bits i will hang onto and sell off later.
#4
ca18_sedan
Posted on: 2006/9/30 5:38
Hey guys, the car is on the market again.
For sale urgently. $8000 or nearest offer, I have signed a contract on a house and another unit today so urgently need money. My loss could be someone elses gain. Cheers Matt You can view topic.
