Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Wanted flex frt brake line for stanza struts(gerlock)
oan878
Posted on: 2006/8/18 10:54
hi just seeing if anyone had any flex brake line for stanza front brakes gerlock ones, before i go and get them made up.
#2
Re: Wanted flex frt brake line for stanza struts(gerlock)
DTW
Posted on: 2006/8/18 14:11
I got braided ones made up and it wasn't that much more expensive than new rubber ones were going to cost if that's any help. Left the old ones at the brake shop otherwise you could've had them. Do the other datto ones fit...??? The guru's on here might be able to tell you.
#3
tappet
Posted on: 2006/8/19 0:08
go to ur local brake shop they will usually make some up..
i was recently told that braided brake lines were illegal, unless approved by adr??? has anyone else heard this?
#4
boofhead
Posted on: 2006/8/19 1:22
braided lines are illegal if they are made by someone who is not registered to make them, all the parts must carry ADR markins and Australian Standards stamps. the lines must be pressure tested and all the rest before they are handed over.
braided lines will cost around $75 and rubber around $40
#5
oan878
Posted on: 2006/8/19 5:29
I just worked out that u can use the rear diff flex line.
i have 2 spare ones i just put on. Not much lefft now it will be goind tomorrow and driviing.
#6
ade
Posted on: 2006/8/20 4:26
which car is nearly finished ??
Ade
#7
oan878
Posted on: 2006/8/20 10:21
one of the four door sedans. I like to take my time on the 2 door. so i get everything right.
so i'm doing a practice run on a 4 door. only been working on it for 6 weeks all up, and its nearly running. quik ca18det convertion. racing it in four weeks at willowbank You can view topic.
